Windows Forum - Computer Support Forums: How to download and (re)install Internet Explorer 6 - Windows Forum - Computer Support Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
How to download and (re)install Internet Explorer 6 Offline install Windows 98/ME/NT4/2K/XP
#1 User is offline   Scarecrow Man
  • Real Eyes, Realize, Real Lies
  • Icon
  • Group: WF Moderator
Posted 15 April 2005 - 21:00
Quote
It is possible to download Internet Explorer for offline installation, which is useful if you have multiple machines to update. You can also download it for all supported operating systems at the same time, allowing you to have a single directory to update a mixture of operating systems.
Downloading:
  • Download ie6setup.exe as normal and place it in it's own directory. In this example we are using "C:\ie6 Download".
  • Create a New Directory for the complete download. In this example we are using "C:\ie6 Complete".
  • Click Start, Run and enter the following command as shown in italics. Make sure you include all of the punctuation marks.
    We suggest you copy and paste the following line, as it must be exact. Replace "C:\ie6 download\" with the location you downloaded the file to.
    "C:\ie6 download\ie6setup.exe" /c:"ie6wzd.exe /d /s:""#E"
    Posted Image
  • When the setup wizard starts, you will be prompted to choose which operating system you want to download for and where you want to store the files. Choose the directory you created above.
    Posted Image
  • After pressing OK, wait while the download is complete.
    Posted Image
Once complete you can copy the IE6 Complete directory to a CD or network location and use it to install on all machines by running the ie6setup.exe file that you will find in the folder.
Installing on a PC:
System Requirements for installing Internet Explorer:
  • A 486 with a 66 megahertz (MHz) processor (Pentium processor recommended) or higher
  • 16 megabytes (MB) of random access memory (RAM) minimum for Windows 98, Me
  • 32 megabytes (MB) of random access memory (RAM) minimum for Windows 2000, XP
  • An internet Connection
Uninstalling the Old Version
If you already have an older version of Internet Explorer on your computer, you do not need to uninstall it before installing this version. Any bookmarks and settings from the previous version of Internet Explorer will be transferred to the new version. You may proceed to the instructions for Installing IE 6.0 SP1.
  • If you are using a Windows 2000/XP computer, log in as an Administrator.
  • Download the installer. (Shown Above)
  • When the download is complete, close all other open programs. Make sure to save your work.
  • Browse to the folder you downloaded the file to and double-click on the ie6setup.exe icon.
  • A Welcome to Setup for Internet Explorer and Internet Tools screen will be displayed.
  • In the Setup window, select I accept the agreement, and then click Next.
  • If you have Windows 98/Me, select Install minimal, or customize your browser. If you have Windows 2000/XP, the only install option available will be the Windows 2000 / Windows XP install option. Click Next.
  • If you have Windows 98/Me, Setup will install the checked components in the list. Click Next.
  • Setup will now install files to your computer. This may take a while.
  • When the Setup is finished, click on Finish to restart your computer.
How to reinstall or repair Internet Explorer and Outlook Express in Windows XP - Microsoft
0
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
