On installation, I selected not to share any files. I am not on a network. I then de-selected wmpnscfg.exe in sys config. I disabled the two (2) BHO it installed (to start automatically). However, when I start the media player...it puts wmpnscfg.exe back into sys config. .....
I have made it clear that I do not want this #%@&^ thing running all the time in the background. Nothing I have tried will stop it. Is there any way (short of uninstalling 11 and using 10) to eliminate this intrusive program?
Page 1 of 1
WMP 11 and WMPNSCFG.EXE
#2
Posted 20 October 2006 - 19:31
Click START/Right click MY Computer/click MANAGE/click SERVICES & APPLICATIONS/click SERVICES/scroll down list to WINDOWS ME.... SHARES WI..../Right click on that entry/ click Properties/from START UP TYPE select disable/ click APPLY/click OK.
♦♠AMD 6000 2 X 3Ghz CPU Seasonic S12 600Watt PSU 8800GTS 640mb graphics card Coolermaster Wavemaster case 2GB Crucial DDR2 6400 2 x 320Gb Hitachi hard drives.
ASUS M2N SLi DLX Wi Fi motherboard.
#3
Posted 20 October 2006 - 21:56
My fault...I forgot to mention that has been disabled as well.
This program will not show up, once you have removed it from msconfig...until the next time you start the media player...then it's a automatic start-up. Sweet huh...won't call home unless you use me.
#4
Posted 20 October 2006 - 22:54
Another thing to try is the box you used for disabling WMPNSCFG.EXE, go to the Recovery tab and reset all three boxes to Take no action and click Apply/Ok and see if that works.
#5
Posted 24 February 2007 - 21:13
Try Startup Cop Pro from PC Magazine - http:\\www.pcmag.com
Sorry, I don't remember weather it is freeware or shareware, but it definitly works to disable programs at startup.
This will allow you to disable the program at startup, but I don't know if it wil come back when you start the media player.
Regards,
Bill R.
Share this topic:
Page 1 of 1
Sign In »
Register Now!
Help
