TL WN550G PCI card and Voyager 2500V
  • Please log in to reply
8 replies to this topic
#1
catgate
catgate
    Bonzai Soup Treader (part time)
  • Member
  • PipPipPipPip
  • 8,886 posts
  • Gender:Male
Some time ago I got a TP Link TL WN550G PCI card and attempted to connect Management's Laptop (PCIMA) with the Desktop box, both on W98SE. I got them to be able to "see" each other but there the matter remained, because the need for the connection was solved by another route. (it was faster to copy to CD than to prat about trying to get them to talk to each other).
I now have the Linux box connected to the 'net, via a BT 2500V modem/wireless router, using the ethernet connections. From time to time we both want to be "Online" simultaneously and I thought it might be achieved by digging out the TP Link card and popping it back into the W98SE box, (which has just had a new MB).
However, after putting the card in, and running the TP Link installation CD, all I get is the ability to "Enable/Disable the Tray Icon" and also look at the "Troubleshooting" facility (which of course is as much use as a pork pie at a Bar mitzvah when, it would appear, the card does not works). The little green light on the card keeps happily flashing green, but that seems to be its limit of co-operation.
I wondered if ZAlarm was putting up a barrier but there is no apparent entry on its list, so I am left wondering "What's Up Doc" and how I can check (easily) the efficacy of the Wireless section of the Voyager and the state of health of my PCI card. (The "copy to CD" is not an option here :( )
What to type into the TCP/IP, UPS, IPA, RSVP boxes is an entirely different matter yet to be conquered,
I would therefore be grateful for any crumbs of comfort that could be directed in my direction.
Thank You. Merci. Danke. Grazzi, usw.
Posted Image
#2
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,767 posts
  • Gender:Male
It should have installed the TP-Link Wireless Client Utility which allows you to set things up. Has it ?
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
Posted Image
Posted Image
"Universally challenged ! " Posted Image
#3
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,767 posts
  • Gender:Male
Also, presumably you have enabled the Voyager's wireless capability ?
Posted Image
Posted Image
#4
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,767 posts
  • Gender:Male
The TP-Link Manual is here (if you need it) http://www.tp-link.c...07116171819.pdf
Posted Image
Posted Image
#5
catgate
catgate
  • Member
  • PipPipPipPip
  • 8,886 posts
  • Gender:Male
Yes, Boris, the TP-Link Wireless Client Utility is installed. That is where I get "Enable/Disable the Tray Icon". All else is 'greyed out' (apart from "troubleshooting)
As far as the Voyager end is concerned I had not considered the 'turning on' aspect of it. I shall have a look at that. Presumably access is through the 192.168.1.1 route.
Posted Image
#6
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,767 posts
  • Gender:Male
Have you looked at Chapter 3 of the manual ?
Posted Image
Posted Image
#7
catgate
catgate
  • Member
  • PipPipPipPip
  • 8,886 posts
  • Gender:Male
Yes I have just downloaded it and I had got to the beginning of that chapter. When I saw the little Bar Graph icon I realised that I had not seen that and on my previous excursion into the exotic world of wireless this had been a sticking point for a while, and I had to have a few goes at loading before it "took".
It looks as though I need to master that little nasty.
Regarding the Voyager the green light on the front, which proudly proclaims "Wireless", is lit and that, according to 192.168.1.1 , appears to be a satisfactory state of affairs.
I shall go and have another poke about trying to get the bar graph icon to appear, by reloading the entire shooting match again (after cleaning it all out), after tea.
Edited by catgate, 27 December 2007 - 19:02.
Posted Image
#8
catgate
catgate
  • Member
  • PipPipPipPip
  • 8,886 posts
  • Gender:Male
It is something akin to juggling with a ton of loose soot, Boris.
Even after some very tasty locally produced and cured bacon chops I am still without my bar chart icon. I have cleared out and reinstalled the TL WN550G thrice and I am still getting no joy.
One thing I have had was a message that said
"ACS.EXE is linked to a missing export ATHCFG11.DLL:?GetProfile@ACAdapterConfig@@QAPAVACProfile@@ABVCstring@@@2" (this last "2" might just be Z, I'm a rotten writer and it has gone now)
After clicking OK, this was repeated with "TWCU.EXE replacing the ACS.EXE but with the same message.
This has happened on two occasions when I have been installing, sorry, trying to install, the PCI card.
It seems that Athcfg11.dll may be a real file in the land of wireless routers, but Googling seems to indicate that it may be a known bug. One individual claimed he had found a "work around".
Should I go back to copying on to CD????? :(
Posted Image
#9
catgate
catgate
  • Member
  • PipPipPipPip
  • 8,886 posts
  • Gender:Male
Since the last post above I have spent several fruitless hours on this project. I downloaded a new driver set from TP LINK's site, and installed and uninstalled several times.
On my last abortive attempt this morning I got the message that "TWCU.EXE has caused a fault at.......etc" so I have binned the PCI card and ordered a new one.
Posted Image
