McciTrayApp.exe - what is it?
  • Please log in to reply
5 replies to this topic
#1
renu
renu
    Newbie
  • Member
  • Pip
  • 8 posts
Hi,
I am seeing this exe McciTrayApp.exe process on my PC. Windows XP. I have Verizon DSL. Can some one tell me what this exe is. It is taking a lot of CPU. I got it from CTRL-ALT-DEL Task manager then Processes.
Thanks for help.
#2
Gagaman
Gagaman
    Novice
  • Premium Member
  • 458 posts
  • Gender:Male
http://www.castlecop...rayApp_exe.html
http://www.bleepingc....exe-18139.html
http://www.what-is-e...rayapp-exe.html
Posted Image
Recently played music:
Posted Image
#3
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,582 posts
  • Gender:Male
If you don't use it, and it uses a lot of CPU, then I would simply remove it from the startup. Use msconfig or Startup Inspector to remove the item from startup (uncheck it, not delete).
Posted Image Posted Image
Doraemon - the robot cat from the future.
#4
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
So it seems to be related to renu's broadband connection, is that right? If he doesn't use that broadband connection, he can remove it, or stop it running automatically. Is that the advice?
"Change is the only constant,
Uncertainty the only thing we can be sure of."
#5
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,831 posts
  • Gender:Male
McciTrayApp.exe
- belongs to the software DVD Solution or BellSouth Wireless Connection or Verizon Online Help and Support or Soldat Interface Maker by Motive Communications, Inc (www.motive.com).
Description: McciTrayApp.exe should be located in a subfolder of "C:\Program Files". Known file sizes on Windows XP are 543232 bytes (74% of all occurrence), 936960 bytes, 935936 bytes.
This file should place an icon in your system tray that can be used to access Help/customer service. If so - and renu does not make use of Verizon Online Help it can be disabled via Startup Inspector so as not to autostart at boot.
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
Posted Image
Posted Image
"Universally challenged ! " Posted Image
#6
renu
renu
    Newbie
  • Member
  • Pip
  • 8 posts
Thanks Gagaman, Pat, Dencandy and Boris for help.
Thanks Pat. I used msconfig to remove it from automatic startup. I will bounce the laptop and see. Thanks
