How do I automatically boot into a user account?
  • Please log in to reply
4 replies to this topic
#1
bob leny
bob leny
    Newbie
  • Member
  • Pip
  • 22 posts
Hi! I have a question...
I am running Windows XP Home Edition.
There are two accounts, Thy God, and Foe #1. Both of which are password protected.
When I turn the computer on, I would like it to just load into Foe #1's account without any prompts.
I was told in the past to got to start, run, and type "control password2". This doesn't work on my computer. I get no error upon entering the command, it simply doesn't do anything... (Weird, on my last computer, which was running Windows XP Home Edition, this worked fine. :huh:)
So, I guess my question is, how do I do this?
Thanks!
Edited by bob leny, 11 January 2008 - 04:36.
#2
Mephisto
Mephisto
    Newbie
  • Member
  • Pip
  • 10 posts
  • Gender:Male
Its "control userpasswords2" (with "s" at the end).
Then uncheck the first checkbox, click on OK and fill up the login you want to use as a default.
Edited by Mephisto, 11 January 2008 - 11:27.
#3
ithonicfury
ithonicfury
    Newbie
  • Member
  • Pip
  • 48 posts
I dont beleive that control userpasswords2 works on home edition (whether you type it right or not). If you get TweakUI then you can set it to automatically login, or set it manually in the registry.
#4
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,767 posts
  • Gender:Male
According to Kelly
http://www.kellys-ko...p_passwords.htm
control userpasswords2 works on all XP
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
Posted Image
Posted Image
"Universally challenged ! " Posted Image
#5
bob leny
bob leny
    Newbie
  • Member
  • Pip
  • 22 posts
Sorry I did respond sooner, but "control userpasswords2" does work. In fact I get the feeling that I had this same problem last time...
It is "control userpasswords2"
not "control password2"
Thanks a lot for your help with my very stupid problem... :wacko:
