Java JRE 6 Update 10 won't uninstall, reinstall, OR install
  • Please log in to reply
19 replies to this topic
#1
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
I was stupid and didn't uninstall Java correctly. I simply deleted the folder without running a proper uninstall. Now when I try to reinstall the same version of Java (JRE 6 Update 10), I get a message asking me if I want to reinstall. When I try reinstalling, I get an error saying "This action is only valid for products that are currently installed."
So Windows somehow thinks this version of Java is still installed...but also uninstalled. :rolleyes:
This java version is nowhere to be found in Add/Remove Programs, and that's because I tried using the Windows Installer CleanUp Utility.
How can I reinstall Java? I don't know where I need to go in the registry, as that's probably what the problem is.
#2
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Welcome to the Windows Forum.
I would think that after running the Windows Installer Cleanup, you should be able to reinstall the JRE? If not, try a system restore to the point before you deleted the Java folder.
If all fails, try to install the latest official release JRE6u6, since JRE6u10 is still beta.
Posted Image Posted Image
Doraemon - the robot cat from the future.
#3
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
I've tried rolling back to JRE6u6 but I think something is still amiss because it doesn't wanna work with Firefox and Internet Explorer (It did before I installed JRE6u10).
#4
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
Also, have you had a look at the official JRE Issues (http://java.com/en/d.../top_issues.xml) help page? There are various threads there that might help you.
Another option might be to uninstall Firefox & IE7, download & install new versions & see if they accept JRE6u6.
If that doesn't help, & if System Restore doesn't help, do you have a systems or registry back-up to the time before you deleted the JRE folder? If so, re-installing that might solve the problem.
Edited by Dencandy, 16 June 2008 - 03:21.
"Change is the only constant,
Uncertainty the only thing we can be sure of."
#5
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
I'm afraid to use System Restore because I recently cleaned some malware off my computer. If the most recent restore point in which JRE6u10 was working properly was a time when I had malware on my computer, will System Restore also restore the malware? That wouldn't be good.
#6
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Yes, a System Restore may very well restore malware, if it was embedded in any system files.
You may need to go through the registry and remove anything related to Java/JRE 6u10.
#7
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
Is there any easy way to do this? I thought I got rid of most jre6 entries but I may not have...Is there an area set aside for Windows installs/uninstalls?
#8
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
This may be a case where a registry cleaner may come handy. I usually do not advocate the use of registry cleaners, but this may be your easiest way to get rid of "dead" registry entries.
Download and install ERUNT and make a registry backup.
Download and install CCleaner, then run the Registry issues scanner.
#9
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
Well, I actually already tried running CCleaner. I still can't seem to reinstall java. :\
#10
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Is this still the message you are getting? This makes no sense - it appears to try a repair install...?
#11
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
Yes, that's the message I am getting. Something is telling the installer that java is still installed, but it's not.
#12
-pops-
-pops-
    WF Moderator
  • Forum Moderator
  • 19,792 posts
  • Gender:Male
You say you have used Ccleaner. Can you confirm it was the registry cleaning part of Ccleaner?
The reason for asking is that this software is normally very good at seeking out bits of the registry that don't belong to anything real, such as partly removed programs.
(\__/)
(")_(")
#13
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Two possible solutions: install the latest version of Windows Installer (4.5.6001.22159), or install the hotfix from http://support.micro....aspx/kb/893048.
#14
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
Aaach. I was so excited because that hotfix directly deals with my problem but it doesn't seem to have worked. I still get the same error. :(
Any other ideas? I really appreciate the help.
Also, I am sure I used the registry cleaner in CCleaner. Still no luck.
Edited by kevrus, 16 June 2008 - 22:07.
#15
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
I also tried solutions B and C on this page: http://consumerdocs....f...4&sliceId=1
However, Solution B does nothing and only brings up a small window explaining all of the different msiexec commands, as if the one provided on the website is outdated?
Solution C didn't work either because right clicking on the setup.exe does not list a version, and neither do the .msi's created in my Application Data folder and Temp folder when the main .exe is run.
#16
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Have you tried the new Windows Installer? (http://www.microsoft...b9-54d056d6f9f4)
#17
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
Yes, I tried that too. :|
#18
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,597 posts
  • Gender:Male
Not much more ideas...
  • install JRE6u10 on another system
  • copy target folder to the current system
  • System Restore to the point before you deleted the folder
If that doesn't do it, then I am out of any other ideas.
#19
kevrus
kevrus
    Newbie
  • Member
  • Pip
  • 10 posts
I really would like to try a System Restore, but that will also restore malware. I tried restoring the folders using my laptop, and Windows doesn't seem to recognize it as installed...
Again, thanks for trying to help me out. I really appreciate it. :) Hopefully I'll magically discover what the problem is. :blink:
Edited by kevrus, 17 June 2008 - 04:20.
#20
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
Assuming you don't have a pre-problem registry back-up (as I suggested earlier) you can do the System Restore, hopefully get the Java settings back so you can uninstall it/them properly, then clean up the malware, then re-install Java.
But before doing that you could try Windows Repair if you have the Windows system disk, but I doubt that will repair something relating to Java. But it's worth a try as it can't do any harm.
Apart from these 2 options the last remaining choice seems to be a full re-install of Windows... :unknw:
P.S. don't forget to save your important data first.
