What C Drive Program Files can I safely delete?
  • Please log in to reply
28 replies to this topic
#1
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Hi all, I am no natural techie but I know I have too much on C Drive slowing things down and want to learn which is essential and which isn't if anybody has any clues?
Bearing in mind all I need for my PC to keep me happy are :
Instant messenger Skype and Yahoo, and a record of chat which I have,
Internet Explorer and Firefox web browsers which I have,
Currency trading stations which I have,
OO.o and Windows word documents which I have,
Be able to make PDF documents which I have,
and to be able to watch videos without stop and start, which I have,
How many of these programs in C drive -> Program files are essential for Windows to run so I know which ones I can delete for more space and then reinstall later if I need to:
Adobe
Ahead
Analog Devices
Apple Software Update
Common Files
CyberLink
Classic
Citrix
ComPlus Applications
Codec Pack - All In 1
instmsia
instmsiw
Intel
Java
JRE
licenses
Media Player
Microsoft ActiveSync
microsoft frontpage
Microsoft Office
Microsoft Visual Studio
Microsoft Works
Microsoft.NET
Movie Maker
MSN->MSN Explorer
MSNGaming Zone
MSXML 6.0
NetMeeting
NOS
Online Services
Outlook Express
readmes
Reference Assemblies
setup Configuration Settings
Windows Live
Windows Media Player
Windows NT
xerox
Thanks in advance
Edited by layresearcher, 02 February 2009 - 00:54.
#2
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
Well he's a start, layresearcher:
- Apple Software Update - you only need this if you use Apple or Mac software.
- Microsoft Works - this can usually be safely deleted unless you use its utilities, which is unlikely since you have Office.
- MSN Explorer - can be deleted if you use Windows Explorer.
- MSN Gaming - can be deleted unless you use it.
- Windows Media Player - can be deleted if you use another media player.
If you later change your mind all the above except MS Works are available for free download later.
Also, do you use Disk Clean Up to clean out rubbish from your Hard drive? Even better is CCleaner (available HERE), a tried and tested utility used by many on this forum to clean out old files and records which are no longer needed.
There are other programs on your list which I know nothing about. To find out what they do you could type them into a search engine and look through what other people say about them.
"Change is the only constant,
Uncertainty the only thing we can be sure of."
#3
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,585 posts
  • Gender:Male
Do not delete anything directly from your Program Files folders; always uninstall applications via Control Panel | Add/Remove Programs. This will also give you more detailed information on what exactly you have installed. E.g. Adobe may be Adobe Reader, Flash Player, or Shockwave Player.
You can give us a full list of your installed programs by using CCleaner (as recommended by Dencandy in the previous post), Tools, tab Uninstall, then right-click on an entry, and select Save to text file. Attach this text file to your next post, and we will tell you what programs can safely be uninstalled.
P.S. I will move this topic to a more appropriate forum.
Posted Image Posted Image
Doraemon - the robot cat from the future.
#4
-pops-
-pops-
    WF Moderator
  • Forum Moderator
  • 19,052 posts
  • Gender:Male
Forgive me if I've misunderstood but:
Are all of these programs running all the time?
Do they all run at startup?
Only a few programs are actually needed when Windows gets going. All the others can be switched in as you require them. A good little utility for removing unnecessary programs running at startup is http://www.windowsst...upinspector.php
(\__/)
(")_(")
#5
ComputerSponge
ComputerSponge
    Newbie
  • Member
  • Pip
  • 4 posts
A good way to clear out unecessary files is using a program like CCleaner. It cleans out unecessary stuff, can clean your registry, and can uninstall programs.
Posted Image
#6
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Thanks for replies members.
CCleaner looks like a great tool.
And other advice will be valuable too.
Been offline alot with alot of Reuter hassels flattie has had.
A friend who told me how knowledgeable he was, reinstalled Windows for me but he made abit of a mess and I still had hardly any space so I started deleting stuff that looked superfluous.
One of the things that I deleted was "Microsoft net framework 2.0" because I think I saw a "Microsoft net framework 3.0" but it seems that was an important component that was needed to accept updates from windows and it also seems to have affected the way I see my screen videos. When I upload them to www.jingproject.com they don't appear the same as they do on my PC.
I have tried to reinstall "Microsoft net framework 2.0" but PC wont seem to accept it now. Can't remember the reason it gave, but should I be able to reinstall "Microsoft net framework 2.0" again?
Thanks in advance.
#7
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,585 posts
  • Gender:Male
As I have replied earlier in this topic, do not delete programs from your computer; use Add/Remove Programs if you want to get rid of it.
As for .NET Framework, version 3.x will not replace 2.x; it will merely build on it. However, .NET Framework is only required if you have any applications that require it. Don't install it if you don't need it! Applications that require it will tell you so, and they will tell you what version they need.
#8
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
A good rule of thumb is initially not to delete anything that has the Microsoft label. But later you can change that as you learn more about which Microsoft components you are likely to need & which you can do without. So first go through the non-Microsoft stuff & decide which you need & which you don't need.
If in doubt just type the name into a search engine like Google to find out about it, then ask the forum if you have any more questions.
#9
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
THanks Pat, I did actually Remove it from "Add/Remove Programs" but still didn't know enough about what i was doing because I think "Microsoft net framework 2.0" has something to do with accepting Microsoft updates which I cant do now.
And it doesn't look like I can reinstall it now either.
#10
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Trouble with me is I struggle with technical language so better off on forums where one can ask questions but some google stuff is clear.
#11
Hb_Kai
Hb_Kai
    The Shoobadooble
  • Member
  • PipPipPip
  • 1,683 posts
  • Gender:Male
A good way is to clean you temp folder too. It usually just fills with junk - C Cleaner which was recommend by ComputerSponge is a really good tool for this and I know most other people will say the same on here.
As for the .NET Frameworks - I tend to keep them all as the software I use nowadays is old and new to some degree and never know when I'll need it - but this isn't always necessary and Pat said more or less the right thing.
Edited by Hb_Kai, 11 March 2009 - 17:54.
<p class='bbc_center'><span style='color: #008000'>Registered Linux User: 500121</span></p>
#12
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
I am realizing that it is quite important to somehow try and reinstall "Microsoft net framework 2.0", because if I don't, it seems I won't be able to receive updates from Windows and various software.
Does anybody know if it is possible to reinstall "Microsoft net framework 2.0" after you have removed it from "Add or Remove programs"?
Thanks
#13
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,835 posts
  • Gender:Male
Just out of interest, when you say that you are "running out of space" on your C drive - just how big is this partition ?
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
Posted Image
Posted Image
"Universally challenged ! " Posted Image
#14
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,835 posts
  • Gender:Male
Thanks
How to manually remove and then reinstall the .NET Framework 2.0 :-
http://support.microsoft.com/kb/908077
You can download the .NET Framework Version 2.0 Redistributable Package from here
Posted Image
Posted Image
#15
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Its 11GB. Flattie put a Linux partition there at some stage, which has since been removed, so I have 7GB of space there with hardly anything in it.
Pity I can't move some stuff from C Drive like program files to there.
Will do a clean to make some room and then try and download .NET Framework 2.0
Thanks
Edited by layresearcher, 11 March 2009 - 22:55.
#16
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
It says I have Microsoft .NET Framework 2.0 but I know it didn't install properly and I got a warning saying so.
I will try and install it again now. I have selected the repair option after downloading it again. (The only other option was Deinstall)
Acrobat.com
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 9
Apple Mobile Device Support
Audacity 1.2.6
AVG Free 8.0
Bonjour
CCleaner (remove only)
Intel® Extreme Graphics Driver
Intel® PRO Ethernet Adapter and Software
iTunes
Java™ 6 Update 11
Java™ 6 Update 7
Jing
MessageMagic
Microsoft .NET Framework 3.0
Microsoft Office Professional Edition 2003
Microsoft Visual C++ 2005 Redistributable
Mozilla Firefox (3.0.7)
MSXML 6 Service Pack 2 (KB954459)
OpenOffice.org 3.0
QuickTime
Skype™ 3.8
SoundMAX
Windows Installer 3.1 (KB893803)
Windows Internet Explorer 8 Beta 2
Yahoo! Messenger
Yahoo! Toolbar
Edited by layresearcher, 11 March 2009 - 23:36.
#17
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Can't seem to edit that last message, but at least I have successfully installed "Microsoft .NET Framework 2.0" on the second attempt so really appreciating the help here.
#18
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,585 posts
  • Gender:Male
Glad you solved your problem with the .NET Framework; the question is - do you actually need it? (Since you originally mentioned too much used space on your C: drive.) If you don't have any applications that use .NET Framework, I'd recommend that your remove both 2.0 and 3.0.
I also recommend that you remove
- Adobe AIR
- Java 6 Update 7.
And while you're at it updating your system, you could also update
- Adobe Reader 9.0 to Adobe Reader 9.1
- Java 6 Update 11 to Java 6 Update 12
- Windows Installer 3.1 to Windows Installer 4.5 (assuming that you have Windows XP SP2 or higher)
When you are done, run the Secunia Online Software Inspector from http://secunia.com/v...canning/online/ - this will show you if you have any other outdated and unsecure software.
#19
layresearcher
layresearcher
    Newbie
  • Member
  • Pip
  • 11 posts
Is this Start Up Inspector ok for windows XP Pops?
Cheers
#20
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,585 posts
  • Gender:Male
Startup Inspector works on all versions of Windows.
