Prefetch data deleted. Help please... :D
  • This topic is locked This topic is locked
12 replies to this topic
#1
Kenny McKetty
Kenny McKetty
    Newbie
  • Member
  • Pip
  • 11 posts
  • Gender:Male
My tuneup utilities 2009 tells me that the files in the prefetch folder, which contain the information about the startup process for windows and programs, were recently deleted.
How can I solve this problem?
Please help.
Thank you.
"The easiest way to grow as a person is to surround yourself with people smarter than you are."
#2
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,429 posts
  • Gender:Male
Do not worry :)
1. Turn off the option to clean the Prefetch in Tune-Up Utilities
2. Windows will just need to re-create all the prefetch files again, thereby slowing down Windows during boot and program starts until all the new prefetch files are created
Windows just maintains the Prefetch folder at a rolling 128 entries - any new applications you run after this number replace the last one that you have not used recently.
See :- http://en.wikipedia....wiki/Prefetcher
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
Posted Image
Posted Image
"Universally challenged ! " Posted Image
#3
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,086 posts
  • Gender:Male
Who/what deleted the Prefetch folder items - that "tuneup" tool? If so, that's a fine "tuneup" utility; it will make Windows startup and applications slower for a while, until the Prefetch folder has been rebuilt.
Posted Image Posted Image
Doraemon - the robot cat from the future.
#4
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
CCleaner used to have cleaning the Prefetch as a default setting. After criticism that for people who tended to use the same core programs each time, it actually slowed the system, it was relegated to an option about 18 months ago. If you've got a version before 2008 it might still be operating as default.
"Change is the only constant,
Uncertainty the only thing we can be sure of."
#5
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,086 posts
  • Gender:Male
CCleaner did/does not delete the entire contents of the Prefetch folder (when checked), but only items not used for a certain period (I don't remember what that period is).
#6
Boris
Boris
    Iconoclast
  • Forum Moderator
  • 7,429 posts
  • Gender:Male
In case you do have problems from any of its actions, you can just access the Tune-Up "Rescue Centre" - which enables you to restore any deletions done and go back to the state before the actions it took.
Posted Image
Posted Image
#7
Kenny McKetty
Kenny McKetty
    Newbie
  • Member
  • Pip
  • 11 posts
  • Gender:Male
Thank you everyone.
The problem is now gone.
:D
#8
scissorhands
scissorhands
    Newbie
  • Member
  • Pip
  • 1 posts
Do not worry
Boris:
I signed up for this forum just to ask you / tell you:
There does not seem TO BE ANY option in Tuneup Utiltiies to turn off the option to clean the Prefetch Data. Where r u seeing this option???
How do you get to this option? I have looked everywhere. Arggh.
I also have the following questions about Tuneup Utilities. Dunno if u can answer them. I emailed the company but haven't heard back:
To make it easier for you to answer - you can just answer in point form under each question if you want. :)
1. How do i prevent Tuneup Utilities from opening at Startup. I didn't see that option.
2. If I do prevent it from opening at Startup, will the changes I made in the wizard to improve my computer performance be reversed??
3.. Why is Tuneup Utilities taking FOREVER to load - not only at Startup, but when I try to open it from the taskbar, etc..? I do only have 256m of ram, but none of my other programs - even my Avira anti virus or my zone alarm take nearly as long.What's going on?
4.. How do I turn off the option to clean the Prefetch??
5. I like the changes it made to improving my DIALUP internet (yes i'm using dialup). info - the tcp info or whatever. But I'm wondering.. if I decide to Uninstall TuneUp utilities, because it seems to be slowing my actual computer down, will those tcp / internet changes be reversed, or will they stay improved?
6. Unlike most programs, if i accidentally click on the tuneup utilities icon in the taskbar more than once, the program opens more than one copy of itself - causing it to take FOREVER for all these copies of the same program to open! Shouldn't your programmers change this?
7. In this "System Performance" section, how do I see which changes it has already made where it says "Optimized." I can't remember all the changes it made, and I would like to find that out.
Thanks!
Scissorhands
Edited by scissorhands, 05 November 2009 - 19:25.
#9
ɹəuəllıʍ ʇɐb
ɹəuəllıʍ ʇɐb
    ドラえもん
  • Forum Moderator
  • 10,086 posts
  • Gender:Male
Welcome to the Windows Forum.
Use a tool like Startup Inspector to find and disable startup items that are not shown by msconfig.
I do not know these "Tuneup Utilities", so I cannot answer any of the other questions.
#10
Tadlac_ASI
Tadlac_ASI
    Newbie
  • Member
  • Pip
  • 1 posts
Please help.
Thank you.
its not the tune up utilities that deleted the prefetch data.. probably.. you are using Kaspersky internet security...
check your kaspersky setting... go to TOOLS... then Privacy Cleaner..... then perform users activity tracers diagnostic,, then click next..
do not check the CLear prefetch cache.....
or check your anti virus setting.. (if not kaspersky)
thanks
#11
roughbeast
roughbeast
    Newbie
  • Member
  • Pip
  • 1 posts
I don't understand the answers that suggest that you can tell TuneUp to switch off the action that deletes pre-fetch data. It is TuneUp that is complaining about it!
The effect of having this data deleted can be profound. Your hard disc can quickly get heavily fragmented and some programs may freeze or crash.
#12
Pradosh
Pradosh
    Newbie
  • Member
  • Pip
  • 5 posts
  • Gender:Male
Edited by Pradosh, 13 September 2011 - 14:22.
#13
-pops-
-pops-
    WF Moderator
  • Forum Moderator
  • 12,699 posts
  • Gender:Male
This is a thread dredged from ancient history and has little relevance now.
Locked
(\__/)
(")_(")
