CoreFoundation.dll not found; what program to be reinstalled?
#1
Posted 14 October 2009 - 04:03
title of message box: "AppleSyncNotifier.exe unable to locate component"
content of message: "This application has failed to start because CoreFoundation.dll was not found. Re-installing the application may fix this problem.
Indeed, yesterday I did delete an Apple program which had the word 'mobile' in its title; I thought it meant 'mobile' (i.e. 'cell') phone, which I don't connect to my computer, so I thought it was not needed. But maybe it meant something else and is needed.
But what is the program to be re-installed?
#2
Posted 14 October 2009 - 04:24
Doraemon - the robot cat from the future.
#3
Posted 14 October 2009 - 04:43
You deleted the program, or you uninstalled it?
#4
Posted 14 October 2009 - 06:54
(\__/)
(")_(")
#5
Posted 14 October 2009 - 07:05
#6
Posted 15 October 2009 - 03:34
Use Startup Inspector to check and remove what's left in the Windows startup from that uninstalled application.
I used Startup Inspector to remove a bunch of programs from the Startup routine, and my Windows seems to boot considerably faster now.
I no longer get the Apple related error message, but I think that's because (before I installed Startup Inspector) I uninstalled all the Apple related programs from Control Panel / Add-Remove Programs, particularly iTunes. I don't use iPod.
However, there's another very annoying error message that keeps popping up, in a small window titled simply 'Msg', in which the message says something like 'The update has not be (sic) found'. Evidently the writer of that is not a native speaker of English. Someone suggested that the language deficiency suggests it's malware, but I'm not sure of that. I use Trend Micro Internet Security, said to be very reliable, and I've run full scan with it, but it has not identified this error message as malware. I just don't know what to think about this.
#7
Posted 15 October 2009 - 04:14
Also, can you start Task Manager, then see what process disappears when you close that Msg window?
#8
Posted 15 October 2009 - 10:53
Can you post a screen shot of that Msg window?
What screeen capture software do you recommend?
#10
Posted 16 October 2009 - 08:18
Have come to my senses and realised I'm not doing the Great North Run any more. An age related decision!
#11
Posted 16 October 2009 - 10:22
I'll try to send a PDF of the screen shot I made using the PrtScn button and Windows Paint. The Msg window popped up during the uninstall-install process of upgrading my Trend-Micro anti-virus program by an internet download.
Being busy with the a-v upgrade, I forgot to open Task Manager when the Msg window appeared this time; I'll try to remember to do that if and when it reappears.
#12
Posted 16 October 2009 - 11:27
Rig 1: Antec NSK6580 / Earthwatts EA-430D - Foxconn M61PMV - AMD Athlon II X4 620 - 4Gb Patriot Extreme PDC24G6400ELK PC6400 -
ECS NVidia N9600GT-512MX-P - 320Gb Samsung HD322HJ F1 - 500Gb Hitachi HDP725050GLA360 - Pioneer DVR-S18LBK - Win 7 Home Premium 64bit
Rig:2 Lian Li PC-7 / Spire SP-ATX-650WTN-PFC Jewel 650W - Asus P5B - Intel Core2 Quad Q6600 - 2Gb Aeneon AET760UD00 PC6400 -
GEForce 7600GT - 160Gb Samsung HD161HJ - 250Gb Samsung SpinPoint SP2504C - NEC ND-3540A - Sony CRX230EE - Vista Ultimate 32bit
Rig 3: Advantage Micro ATX / Coolermaster GX 450W 80PLUS - Foxconn G31MX-K - Intel Pentium Dual-Core E5800 - 2GB Melco PC6400 -
Sweex HD4650 - 320Gb Samsung HD322HJ F1 - Samsung SH S223B - Vista Home Basic 32bit
Rig 4: Antec SLK3000B / Coolermaster 460W eXtreme Power Plus - Asus M2N68-AM Plus - AMD 64 X2 7850 BE - 2Gb Patriot Signature PSD22G8002 PC6400 -
Asus HD4670 - 250Gb Excelstor Jupiter J9250S - 500Gb Western Digital WD5000AAKS - LG GH22NS50 - XP Home SP3
Rig 5: Antler Mercedes PC 179 / Hiper 530W - MSI K8N Neo 4 Platinum - AMD Athlon 64 X2 4200 - 2Gb Crucial CT12864Z40B PC3200 -
GeForce 7600GT - 80Gb Western Digital WD800AAJS - 500Gb Seagate Barracuda ST3500418AS - Pioneer DVR-111 - HP 1040i - XP Home SP3
"Universally challenged ! "
#13
Posted 16 October 2009 - 14:02
IMHO I think that it is a Gigabyte product on your machine (probably the motherboard) attempting to update drivers for itself automatically ?
Yes, I do have a Gigabyte motherboard, and last week I installed a package of utilities from the CD that came with the motherboard. The suite of programs does include a so-called 'Update Manager', which has an executable file called 'UpdateSettingDig.exe', which apparently allows me to configure options for 1) updating at a regular time interval, 2) updating at bootup, and 3) not updating. So I'll first choose the no updates option, and see if the messages, which I thought were an error but apparently are not, stop appearing.
Beyond that, there's the question whether this program could bring some benefit, if allowed to run. I'm not quite sure what is being updated. Is it some driver or drivers for the motherboard itself?
Other programs in the suite include onces called Energy Saver, BIOS upgrade, Q-Share (whatever that does), Easy Tuner, and Face Wizard. I'm a bit wary of trying them, because I have no technical understanding of BIOS, for example, or of what might be involved in tuning the functions of various things in the m/board.
#14
Posted 16 October 2009 - 17:39
See http://www.gigabyte....ility_List.aspx
The blue "more" hyperlinks will tell you what they do.
Whether you use them or not is up to you ..... but the old adage always was "if it ain't broke, don't fix it"
#15
Posted 18 March 2011 - 08:40
#16
Posted 20 March 2011 - 01:51
Back to top
