Can't Delete A File in Windows Media Player
  • Please log in to reply
6 replies to this topic
#1
rondo9
rondo9
    Newbie
  • Member
  • Pip
  • 3 posts
I have a problem. I have a file on my Windows Media Player that I cannot remove. I've tried to delete it. It's not in my music file any where. And defragging does nothing. How do I remove it? For further details look below at the screenshot.
View a screenshot of it here: Posted Image
http://img297.images...60/37452469.png
#2
Irene
Irene
    Expert
  • Forum Moderator
  • 8,899 posts
  • Gender:Female
There is a Billy Joel 'icon' on the bottom left of your screen shot. Do you have that track/album?
If you change the sort to 'Album' from 'Genre', does it show it as Billy Joel?
Have you tried a right-click on 'Unknown Album', then select delete from the short menu?
#3
rondo9
rondo9
    Newbie
  • Member
  • Pip
  • 3 posts
It shows up as an unknown album, song, genre, everything.
If I click properties, it shows that it has no length, no codec, nothing.
The music I'm listening to is completely irrelevant. It has nothing to do with the music.
Edited by rondo9, 20 May 2010 - 01:27.
#4
Dencandy
Dencandy
    Advanced
  • Member
  • PipPipPip
  • 1,794 posts
  • Gender:Male
This is one of several flaws in Windows Media Player library system. Sometimes you can delete such a record by trying to play it, then WMP will tell you it can't find it & will ask you if you want to delete the record.
If that doesn't here's a link to a thread about finding WMP media files & deleting them: TECHSUPPORT
"Change is the only constant,
Uncertainty the only thing we can be sure of."
#5
-pops-
-pops-
    WF Moderator
  • Forum Moderator
  • 19,713 posts
  • Gender:Male
I recall having a similar problem with an early version of WMV. What I did was rename the file and delete that. Don't know whether that will work with your file.
(\__/)
(")_(")
#6
rondo9
rondo9
    Newbie
  • Member
  • Pip
  • 3 posts
I can't delete it, rename it, rate it, nothing.
#7
sorush.nazari
sorush.nazari
    Newbie
  • Member
  • Pip
  • 23 posts
Have you tried to clear the songs cache?
